bathroom light blows circut when shut off
Hey...im very confused. we are remodeling our bathroom (making larger) and I need to move the light switch to the other end of the room, and the light fixture to the ceiling instead of the wall. So as far as I know, I am basically moving the location of these items, but I am replacing said swith and fixtures. I need to purchase new wires as the olders ones were a bit raggedy looking and to short. Commen sence told me that the black went to black and white to white...done. When I turned the power back on, the light was already on even though the switch was set to off. I turned off the power switched the wires at the switch, turned on the power and the same thing. even worse when I flip the switch to the opposite direction it starts humming and the circut blows. I am very confused, and dont know what else to do...please help!!!
Brian
Brian
Received 0 Votes
We need more information:
(1) Does the incoming unswitched power come into the switch box or into the light fixture box?
(2) Please describe all the wires in each box (how many cables, what color wires) and how they are connected to the switch and to the light fixture.
There are two most likely errors you made, but we need the answers to these questions to determine the solution in your particular case.
Received 0 Votes
Sounds like you tied all blacks together and all whites together at the light fixture. At the switch black is on one screw of the switch, white is on the other.
To fix - leave the switch alone. At the light, unhook the wires and connect as follows:
(1) White from incoming power to white of fixture
(2) Black from incoming power to white from switch
(3) Black from switch to black of fixture
If there are more wires than these at either the light or at the switch (ignoring the ground wires) don't do anything and post back.
I don't know who you are but I think I need you as my new best friend. IT WORKED thank you SOOOOOOO very much. This is just the start for me as far as wiring goes for my new bathroom, so I'm sure I will be back for more answers, your the best, thanks a heap
Brian
Brian
It's been my experience on this forum that nothing garners undying gratitude quite like helping someone with a switch loop. Telling someone how to correctly wire a switch loop always seems like magic to someone for whom black-to-black and white-to-white has just failed.
Good job mikewu99!
Good job mikewu99!
