Good Morning,
I have a florescent light fixture in my bathroom. Initially, I thought the bulbs had burned out since the light tries to go on but does not and the bulb seemed a bit black at one end.
I bought two new florescent tubes and the same thing is happening. One tube tries to light, but does not and the other does not work at all.
Is this a starter problem. If so, can I fix it myself or should I call an electrician?
Thanks for any response I may receive to this question.
Mary
Hi
Last night part of my power stoped working. One outlet, 2 rooms, and a hall closet. They are all on the same breaker. I checked the breaker and it did not turn off. I turned it of and on to see if that would reset it, but got nothing. I even replaced the breaker with a new one and still those area's did not work. The rest of my house is fine. Any ideas on what I can do to fix this.
