Bathroom remodeling wiring
I'm updating a small bathroom, and have a 3 gang box for a GFI receptacle, and two switches for fan and lights. I can wire the hot line in to the GFI ... how do I wire the hot and common wires from either the hot line or the GFI to the two switches?
Take your pick. I'd wire them to the load side of the GFCI using pigtails to reach both switches. If you later find that the fan is tripping the GFCI (not very likely), you can always rewire them to the line side later.
