Change from 15 to 20 amp?
I am adding some additonal lighting outside my house and after adding up the amps needed I came to realize that my 15 amp breaker wouldn't be quite enough. Can I simply change from 15 to 20 amp breaker considering there are many 20 amp breakers already in the panel?
the only way this can be done properly is if the wire on the circuit is 12 guage. i sincerely doubt the builder ran 12 wire and only put in a 15 amp breaker. it seems like you will need to run a seperate circuit to do what you plan.
