wiring a 3 way switch with BX
i have 3 questions relating to my sconce that i'm installing to a 3 way switch.
1) The sconce has aluminum wires. do i connect these with regular wire connectors to my copper wire that runs to the power source?
2) one run of the 3 way leg is old BX wire, grounded with a metal sheath. does the sheath ground by being connected with a compression fitting to a metal junction box? also, the older copper wires are in really good shape (no cracked insulation, but the copper is really dark. is this ok to connect to the new copper wires?
any other advice on working with old BX that is in otherwise good condition? i'm a bit confused on how the metal sheath serves as the ground.
3) does it matter what kind of screw (metal type) that i'm using for or the grounding screw? my current box has no grounding screw, so i was going to take another screw and use that as the grounding screw.
Re: wiring a 3 way switch with BX
Received 0 Votes
Yes, it is Red Hat Linux 8.0. Just take that CD, heat it up a bit, and mold it over the sharp edges of the BX. It's what Torvalds would do!
Or perhaps Joe means anti-short BX flex bushings, those plastic things that protect conductors from sharp edges. Cost a few cents each and come in bags.
