electrical
electrical
Is there a minimum height above floor level, that you have to maintain when installing a 220vac oven receptacle. If not; what is the norm?
Thanks
Thanks
No minimum. No maximum. You shoulld look at the installation instructions for the stove if you can. Some have a limited area that has sufficient clearance for the plug and still get the unit all the way against the wall. Often the only clearance is within a few inches of the floor.
