Holes in Stud..
Received 0 Votes
Holes in Stud..
Can any one tell me how many holes you can drill into a stud for Romex. I also understand that you can "skip" going through alternating studs under certain conditions.
thanks
thanks
Received 0 Votes
You could drill lots of holes, in the middle, and you shouldnt really have more than 2 or 3 wires thru any one. There are some cases you could alternate as long as the wire wouldnt be exposed or pinched. I have never really heard of a rule about amounts in studs.
If you finish a basement and leave the studs out from the wall you can skip boring for NM. It is only required to be supported every 4.5 feet. (334.30(A)) Between the back of the stud and the basement wall is not an exposed location and no additional protection is required.
It is a sloppy practice and does not look very workmanlike. Check with your AHJ. I have worked in areas that allowed it, and areas that did not. I do not do it. Threading the wire behind the studs will not really save enough time to matter. Use a 24 inch auger bit to bore, and alternate the side you bore from and the pulling goes a little faster.
