Turning old chandelier into "plug-in"
I have an old, 8 bulb chandelier I want to put in an area that does not have wiring to ceiling mount it. SO, I was wondering if I could just buy a swag light kit, and make the chandelier a "plug-in"? would this work? or would it be too much wattage for my wall outlet? thanks you for your info!!
I did it.......
Hi john, I got your message too late. I bought a "plug in" swag light kit and hooked it up to the chandelier. I only screwed in one 25 watt bulb out of the 10, and plugged it in. It worked great! But then I read your response and decieded to wait to screw in all 10 bulbs and plug it in. what do you think would happen? I really want this chandelier to work out as a "plug in", but i do want to be smart about the whole thing, so any and all info about what could happen is appreciated. is it at all possible? thanks!
It'll probably be fine. The issue is that when you change the design of a fixture, then all the testing that was done in invalidated. I can't point to anything specific that might go wrong, but there might be some hidden hazard.
10 x 25 = 250 watts. (Is it 8 bulbs or 10?) Either way, it's not a major draw for most household circuits -- depending on what else is plugged in on that circuit.
My concerns would be to make sure the wire splice is done inside the fixture -- replacing the original "main" wiring if possible -- and to remove the ceiling cover altogether. Fasten the swag chain directly to the fixture.
Can you post a pic of the fixture?
