Hot water costs
Hot water costs
Will switching from a 30 gal. to a 80 gal. electric water heater in a situation where alot of hot water is used (8 kids) reduce the electric bill enough to make a noticable difference? Many Thanks.
Received 0 Votes
It wont really make any difference. The only way is if it is on a timer where you can buy power on off peak hours. It still takes the same BTU's to heat a gallon of water in a big heater or a small heater. If you have any other gas appliances that might be an option as I think it is cheaper. If you have any way of preheating water it really helps. I have 4 well tanks painted black sitting in the sun for my migrant shower house before it heats a booster heater (if needed) and it saves gobs of gas for multiple showers and laundry. That would depend on the climate for year around use or you could valve that setup for summer use. Its a version of solar panels which would also work.
I don't think it will reduce your bill at all. It will only give you more available hot water. You still have to heat the water you use. It might even cost you more because running out of hot water would restrict the amount that could be used in one use.
Received 0 Votes
Some of us go right on by and miss the reality of it all. Sometimes it doesnt have anything to do with electric does it? That wouldnt have occured to me to answer it that way,,, but come to think of it I have done that myself.
