Wiring a transfer switch for generator
Old 02-26-03, 09:13 AM
Herm's Avatar
We have a portable generator (about 5000 watts). I hate having to run extension cords all over the house from the garage when the power goes out. The other problem with extension cords is not being able to hook up the furnace.
I know a little about manual transfer switches by visiting some other websites, but I was wondering if anybody knows of a good website for the do it yourselfer. I do have a friend that is an electrician that is going to help me, but I want him to just supervise, and not take up too much of his time.
I only want to run a few critical circuits.
Sump pump
refrigerator
furnace
sewage ejector pump
maybe a circuit for the tv and a light
Any help would be appreciated.
Old 02-26-03, 12:34 PM
HandyRon's Avatar
Below is a good DIY website.
http://www.homewiringandmore.com/hom...generator.html
You must use some sort of transfer switch, which will not permit the connection of the generator conductors to the utility conductors. Many hardware stores have small panels that act as transfer switches on a per circuit basis or group of circuits.
Old 02-26-03, 05:35 PM
Received 501 Upvotes on 411 Posts
This is the device you need.
http://forum.doityourself.com/showth...hreadid=123394
It is simple to hook up. You pick the six circuits you want to transfer. remove the wire from the breaker and connect to the wire from the transfer switch. Take wire from transfer switch and hook to breaker. Do it 6 times and you have it connected.
Here is the one they sell at home depot. It comes with the flex cable and wiring al ready to go.
http://www.connecticut-electric.com/switch.asp
Old 02-26-03, 05:47 PM
Kooter's Avatar
Received 88 Upvotes on 81 Posts
Look at this Generator Panel too:
http://www.squared.com/us/products/l...568d3006c65f9/$FILE/40266-223-03E.pdf
Kooter
Old 02-26-03, 08:46 PM
Herm's Avatar
Thanks for your posts!
These are all very helpful links. Thanks.
I let you know what happens
Herm
