Outlets no power
Old 03-01-03, 01:17 AM
goldjag
Unhappy Outlets no power
I recently had to have repairs on gas furnace (ignition module??). The repairman said I didn't have to be home when part came in for him to repair. The heat works great but outlets in two bathrooms and garage have no power, which I discovered when the water begin to leak from freezer. Company said repairman turn off power from main switch at heat unit and this shouldn't have damaged anything. Salesman at local store said breaker should appear half off (all looked the same). I turn them all on and off still no power. Is this a job for a professional or is it possible for me to fix?
Old 03-01-03, 02:14 AM
Look around in the garage for the ground fault interupters and reset them. Amazing enuf they put them in the garage sometimes that fed the bathroom,, why I dont know.
Old 03-02-03, 01:10 PM
goldjag
Talking Power's back to outlets!!
Thanks sberry27 !!! I would have never thought of looking in the garage for the reset button.
