IC Hi-Hats and attic insulation....
Old 03-03-03, 09:55 AM
DIY124
Exclamation IC Hi-Hats and attic insulation....
Just installed hi-hats recently in my attic. I used IC cans, understanding that these can be used with insulation - but, what are the rules with this? The guys at the big 'orange' give me confilicting answers. Is it a three inch space from the can and nothing above, can I insulate over the cans? I have not hooked up the power yet.
Thanks!
Gary
Old 03-03-03, 11:01 AM
A
Master Electrician
The conflicting opinions is coming from type IC, And type Non-IC.
If the can is Type IC then you can insulate around, and on top, If it is Non-IC then 3" have to be maintained.
NEC 410.66 2002
Old 03-03-03, 12:15 PM
DIY124
Question IC cans and insulation continued...
This means that I can butt up the insulation to and over the can, or just over the can?
Old 03-03-03, 01:43 PM
JRRR.
Fellow frustrated novice here. IC can lights can be insulated up to and over them. Remember to use unfaced fiberglass insulation when doing so. I believe the paper on kraft faced batts is extremely flammable. I installed IC cans in my daughters room when I redid it. I used unfaced fiberglass up to and around these lamps. I did not opt to insulate over them just in case. Most can light have a thermal breaker in them that will discontinue lamp operation if it becomes to hot.
Old 03-03-03, 01:55 PM
A
Master Electrician
"To and Over" the can is ok.
Something I want to point out is "some" not all of these great hardware stores we have can miss-lead you to believe that you have bought an IC can.
The noticeable difference you will see is in the "can" itself. Not only a Tag will identify the can but,
An "IC can will not have vented holes in the can itself. "Sometimes nothing bigger then a few holes". Type Non-IC "cans" do have vent holes, and this is how more heat gets to the insulation in the attic or anything surrounding the can.
Old 03-03-03, 02:41 PM
texsparky
Post FYI
FYI-- The IC stands for in-contact,meaning that it is OK for the insulation to be in direct contact with the cans.
Old 03-04-03, 06:54 AM
DIY124
Thanks guys -- this was a great help.
