Reparing wire damaged insulation
I have a couple of solid wires in metal closed box with damaged insulation. How can I repair them?
Depending on where or how far back the dammage is I usually just wrap the dammaged wire with some Good electrical tape (SCOTCH 33+) or if it is more delicate shrinktube is a good way to go also. Both items are readily available at your local hardware or electronics store. Good luck hope this helps.
