Electrical Panel Instl
I'm replacing an existing Electrical Panel in my detached Shop. The existing Panel doesn't have a main. Installation of a 125A main doesn't allow for sufficient quantity of Breaker spaces to support all existing curcuits in the Shop. I'm installing a Square D (Homeline 125A) with an integral Main. This Panel is slightly larger than the one being replaced and the feeder Cable from the service in my attached Garage (1/0) is to short when I attach the existing branch curcuits (Lights, outlets ect). I'll have to replace either the feeder Cables or the initial lenght of each branch curcuit. Question: 1) Is there a min. - max height requirement for the Panel ? 2) Can I rotate the Square D Panel 180 Deg. ? If I can rotate the Panel (main on the bottom) all Wire is sufficient for length. The Plastic Breaker receptical is attached to the panel with a single Screw and (4) tabs.
Thanks
Rich
Thanks
Rich
Yup, like Tex says, flip it over,, you see them all the time done that way and thats why. The electric will just have to work a bit harder to push up the buss instead of having gravity do its thing and letting it fall to the secondary breakers.
