Electrical Panel
Old 03-30-03, 11:19 AM
rpotts
Electrical Panel
I am curious about the larger or inductive loads in a panel. Should they be positioned with the larger loads close to the main breaker and then working your way to the smaller branches? I have a top fed panel and I have noticed the 40A range and 30A AC branches are at the bottom. Maybe there is no rule of thumb.
Old 03-30-03, 11:22 AM
Received 1 Upvote on 1 Post
They are usually at the top, but it doesn't make that much difference.
Old 03-30-03, 07:47 PM
rpotts
Thanks John.
I am finishing my basement and thought while I was in my panel I might move some of the branches if it made sense. I guess I will just leave them and add my basement circuits.
Old 03-31-03, 08:11 AM
It makes no difference, but there is one thing to avoid when positioning breakers in a panel, which could easily cause a problem if you put all your largest loads at the top of the panel - never position your largest breakers opposite each other. Breakers opposite each other share the same "tab" on the bus bars. If you have a 90 amp electric heat load opposite a 50 amp electric range, the heat can really build up on that section of the bus bar. I've seen numerous failures because of such.
I generally install all of my 220 volt circuits down the same side of the panel. This puts them on top of each other and guarantees that I won't have large loads across from each other.
Old 04-02-03, 07:03 PM
rpotts
Thanks mcjunk. I had not thought of that.
