Cooker control unit
Old 03-31-03, 10:56 AM
dykemrtn
Question Cooker control unit
Just about to change the old gas cooker for a new electric cooker, the wiring is in for the cooker unit and cooker connection unit both are rated at 45 amps.
The electric oven is a straight forward 6 mm cable from the oven to the cooker connection unit, now the problem is the gas hob has a small flex for the ignition of the gas, do i have put a spur in from the ring main to power the ignition or can i come of the cooker unit with a spur ?.
Worried about the cooker unit and spur rated at 45 amps and the flex will carry only about 3 amps ....... HELP as the wife needs to do some cooking ..........
Old 03-31-03, 03:31 PM
Received 499 Upvotes on 410 Posts
You are in UK by the sounds of your question. I don't know if any brits hang around at this site.
Try this site. It has a UK section.
http://electrical-contractor.net/cgi...i?action=intro
