Running Romex to pass code
Received 0 Votes
I am running Romex in an unfinished 2nd Floor. I have strapping running across the ceiling joists for the sheetrock to be installed later. Is it OK to run the Romex between the strapping paralleling the strapping and stapling every other joist?
Received 0 Votes
Joe, it's 1.25" and the rule is for bored holes. If the NEC says something about straping, I don't know what it is.
Received 0 Votes
The joists
I know enough to keep the wire stapled up when papalleling the ceiling joists....I just thought drilling holes in the ceiling joists would ruin the structual integrity especiall if you ran it nice and straight....what a weak point it would create! While I'm here....While in the attic, I ran Romex across the common rafters with these plastic adapters that hold multiple wires...My brother said he thinks that the inspector won't allow it, because someone will try hang things on the wire, He said I'll have to either install backing or remove it and secure it to a 2X4....I think he's assuming/guessing and doesn't really know! Your thoughts???
Althougth there is not a code violation in your original post, I do not like that application.
A properly drilled hole, in the middle third of a 2X, should not effect its integrity.
If you are running perpendicular it will not pass, if parallel it will be OK.
Mike
Mike
Received 0 Votes
runing the wire
I think the purpose of the wire being above the edge of the joist 1.25" is to prevent a nail penetrating the wire from the drywall crew. But, when running the wire between the strapping (12"O.C.) I don't see how they can hit that unless they're wreckless!!
On the other hand Jxofaltrds, did you say that running the wire across the common rafter (perpandicular ) in a storage attic is a NO-NO?
Calling it a "storage" attic might cause a problem. Like stapling under floor joists. Just call it an attic.
Mike
Mike
Received 0 Votes
Is it acceptable to run romex across the roof rafters using the plastic clips I was refering to, (they have about 4 slots)?
Previous Thread
Next Thread
