Ceiling light fixture
Old 04-07-03, 08:25 AM
rae4622
I am trying to install a new ceiling light fixture in place of a ceiling fan. The problem is the nipple is not long enough to go through the globe. I currently have the mounting bracket as low as it will go (it's even a 1/2 inch below the ceiling level) and the hex nut as far to the top as it will go and it's still too short. Is it a common problem to have the nipple be too short or am I doing something wrong?
Thanks
Old 04-07-03, 09:12 AM
Received 1 Upvote on 1 Post
Pretty hard to tell from here. Perhaps you are doing something wrong, or perhaps they packaged the wrong nipple with the fixture. Carefully restudy the installation instructions first, and then go back to the store and look at another light of the same kind. Maybe you can even look at an installed one in the store.
Old 04-07-03, 09:48 AM
rae4622
Thanks, John. I've looked over the instructions a million times. I'll be going to the store tonight to probably buy a longer nipple, I'll check their installation as well.
Not sure if I should re-post this or ask now, but I'm not sure the type of switch to install for this light fixture. I'm a newbie at this, so bear with me...As I said, it was a ceiling fan controlled by two switches in one box. One switch turned on the light, the other turned on the fan. From the ceiling there are the typical 1 ground, 1 black, 1 white & 1 red wire. The switch box appears to only have one cable running into it. I'd like to replace the two-switch with a standard one switch, but the 'expert' at Lowes couldn't tell me which type I needed. Can you help from this explanation??
Old 04-07-03, 10:10 AM
If you connect the light to the red wire, one of the switches will operate it. If you connect it to the black wire, the other switch will operate it.
Do you currently have a duplex switch? I.e., two switches in a single-gang box, one on top of the other?
An ordinary single-pole switch, the kind with "on" and "off" on the lever, will do just fine. Probably cost you a buck or less.
Old 04-07-03, 10:20 AM
rae4622
Yes, it's a duplex switch. I thought it would be a simple switch replacement, but the person at Lowes got very confused at my explanation and asked me to take pictures of it.
I am to assume that I just put a cap on the red wire at the switch box and tuck it back?
Thanks so much for your help!
Old 04-07-03, 06:25 PM
Yes, put a wire nut on the red wire at both ends. It would be a good idea to tape a little note to that wire saying that it is a spare wire for a ceiling fan. Somebody will want to put a fan back there someday.
