Central AC outside Fuse Box
What is the reason why a Central AC Unit has an outside fuse box instead of a circuit breaker. Even on new installations I see a fuse box used on the outside of the house. (The pull out type fuse squares).
Generally, electrical code requires a local disconnect within sight of a motor.
Some A/C manufacturers require fuse protection (not circuit breaker) for the equipment. So the local disconnect gets installed as a fused disconnect.
Most HVAC manufacturers are listing the equip for a fuse or HACR circuit breaker. Some are behind the times, and keep the old listing for fuses only. If you compare the characteristics between a fuse and circuit breaker, they offer much of the same protection to the load. The additional benifit of a breaker is that the unit will never lose just one phase and burn itself out.
HandyRon,
I never thought of that. The main reason I don't like the fuse is that when they pop what do you do? Sure you can replace them, if the nearest supply house is open. So at 8:00pm Friday night when a freak thunder storm causes your AC fuses to pop your now stuck until Monday with no-AC. Not my Idea of fun.
