Existing lights question
Old 04-17-03, 06:05 AM
T
I was in the basement last night looking at the new lights I installed when it occured to me that I still have the existing lights and circuit to deal with. I have 4 pull-chain lights on an existing circuit that will no longer be needed when I cut over to the new subpanel in the basement.
What do you typically do with these? Do I need to take them out and disconnect them at the source (not sure where that is at the moment). If I were to just leave them there, I'd have to leave access to them since technically they'd be junction boxes, right?
Thanks,
Jim
Old 04-17-03, 06:32 AM
Received 1 Upvote on 1 Post
Yes, you will need to take them out and disconnect them at the source (you should figure out where that is). If you still need them temporarily during construction, you can leave them there for now. If you can't find the source (e.g.., the cable disappears into the wall or ceiling), I suggest that you convert the fixture closest to the source to a receptacle, locating it at the most convenient place that the cable will reach to.
And you are correct, you need permanent access to all wiring that you can't disconnect at the source.
G
yes even if you are not going to use them if there are circuits in them they must be assessable. you could remove them totally which might be the easiest route but you have to look into each one and see if anthing else is fed off of them, because if there is then you will have to leave them or reroute the power to what is being fed. It is not uncommon in basements for the lights to feed a receptcle somewhere as home owners usually find them a easy source of power to something they decided to put in on the first floor of the house.
Old 04-17-03, 07:17 AM
T
I'll have to look and see where they get power from and what else they feed. 2 of them look like "end" boxes - only one wire to them. That means that they're either on 2 different circuits (not likely) or that they feed something I can't see and come back. I'm the original owner of the house, so I know no one has tapped anything strange off of them. I'll just have to flip the breaker off and see what else goes out.
Either way, the unfinished storage area is at the end of the basement where all of the wiring enters the house from the main panel. If I can trace the wire that far back, I can use that circuit for an outlet (GFCI, says the code guy) in that area and feed whatever else is on it from there.
I don't really need them anymore since I've been using halogen worklights anyway. But I don't want the code guy to come by and tell me that I shouldn't be disconnecting and moving things yet.
Thanks,
Jim
