GFCI Outlets
This is one i havent heard b4. My brothers house had a GFCI outlet that keeps tripping on its own, so i replaced it and ckd the wiring and the ground and everything is right. It still intermittently trips, im stumped im just a low voltage electrician, any ideas are appreciated.
GFCI outlets
You might also want to check the breaker that controls this outlet as well as the appliances that are plugged in here. In houses where I have lived where my blow dryer started turning off the outlet, it was a sign that my blow dryer was on the way out. I am sure with all the wiggling of the blow dryer to blow my big head of hair dry, that I develop a short in the dryer. I am not an electrician, but this is a thought. Check the appliances as well as the breaker if you have installed a new receptacle.
