Outlets
Old 04-20-03, 05:35 PM
Tom
Outlets
If you wire a room with #12 wire on a 20 amp breaker, how many outlets can you put into a room? The location is a family room.
Old 04-20-03, 05:45 PM
Received 1 Upvote on 1 Post
This is one of the top five questions asked on this forum. The answer is that the National Electrical Code places no limit on the number of outlets on a circuit. Some local juristictions do, so check locally.
The normal rule of thumb for a 20-amp circuit is 10 outlets, but you are generally free to go up or down from that number based on your knowledge of how the room will be used, and how much power that activity will require.
Old 04-20-03, 06:11 PM
gastrek's Avatar
I had the same question. And I have another one that will make me sound dumb. (not the first time). By 10 outlets, do you mean 5 duplex recepticles or do you mean 10 duplex recepticles?
Thanks.
Old 04-20-03, 06:22 PM
Ten duplex receptacles.
Old 04-20-03, 09:30 PM
gastrek's Avatar
Thanks John!
