help
Old 04-21-03, 10:26 PM
mics111
help
power went out for 5 hours the other day..now my stove wont work and some of my lights are dim...stove ligt and range lite work but do not heat up..also light in kitchen is dim..have reset all breakers...what gives?
Old 04-22-03, 05:54 AM
txdiyguy's Avatar
Sounds sort of like a "partial power" situation which means one leg of your service is out. You don't have any 240 volt and the dim lights are a result of feedback through one of your 240 volt appliances. Was your stove on when the power went off?
Old 04-22-03, 06:29 AM
Received 500 Upvotes on 410 Posts
One side of your 240 is out. Call the power company and have them check the connections.
Old 04-22-03, 06:32 AM
Handyone's Avatar
Sounds like you'd better call an electrician, unless you're very handy with electric. Your main incoming cables to your service panel may have burned up. This could happen on the terminals on the back of your meter (connection may have been loose and caused wires to burn off the terminal). This would give you 110V on some breakers and zero volts on other breakers.
Brian
Old 04-25-03, 08:50 PM
mics111
thaks for your help..turned out to be main breaker...read 120 at top and bottom..but when i put a load on it ...it read 79volt and 89 and bottom
