Subpanel instal questions
I upgrading the electrical in my parents home and need to replace the old fuse boxes with a subpanel. The house was remodeled in the 60's and a 200amp service installed. The old service bacame a subpanel with an assortment of small fuse boxes hanging off it. I am replacing that mess with a new subpanel.
My questions concern wiring between the main panel and new sub. Currently there are three wires feeding the subpanel (2 hot, 1 neutral).
Question #1: Do I need to add a ground wire to link the ground buses on the main and subpanels? If so is that the only grounding point for the subpanel?
I know that the neutral and ground busses cannot be linked in the subpanel.
Question #2: Is it permissible to have a splice in the circuit feeding the stove or other major appliance? I would like to run new wire from the subpanel to the old subpanel and use it as a splice box.
First a caution: It is almost certainly not legal for you to do wiring work in your parents' home.
Second, I am going to assume that the main panel and subpanel are in the same building. It sounds like they are.
1. Yes, and yes.
2. Yes.
1. Yes, and yes.
2. Yes.
Thanks for the response.
I am an owner of the house so doing my own wiring should be fine. I also obtained a permit for the work since I want to have it inspected and on record when the house is sold.
Follow-up question.
What size ground wire do I need to use? The subpanel is about 35 feet from the main. I assume the ground wire can be bare.
Follow-up question.
I plan replacing the exisitng wire and using #4 wire. I assume the ground has to be the same size as the others.
I have 1" flexible metal conduit in place to the old sub-panel. Just need to pull out the old wires, shorten the conduit and it attach it to the new subpanel.
Is 1" FMC too small for 3-#4 wires plus ground?
Thanks for your assistance.
David
David
From 2002 NEC ANNEX C Table C3
For 1" FMC----Type THHN, THWN, or THWN-2 # 4 = 4 conductors
Ampacity from Table 310.16 (75deg.C column) #4 copper = 85 amps. Ground wire could be #10 copper for a 60 amp feeder or # 8 copper up to a 100 amp feeder.
