moving dryer to a new location!
Hello, i need to move my dryer to the garage because is in the kitchen now and is gas. i've got all the materials for the job, cable (4-conductor) wall outlet and the new cord to match the new installed. the house was build in 1955 and i do have a dual 30-amp breaker that was use for a dryer at one time, i see that i only have the neutral bar and all neutral and grounds are connected to this bar, how can i connect this 4-conductor cable to work properly?? can i connect both grnd and neutral to the same bar?
Sounds like you're all set. If this is the panel where the main disconnect is, you may connect the white and bare wires to the same bar. In most panels, a white wire may not share a screw with another wire. The new receptacle has four holes, right?
