Wiring For Tubes With Switch
Old 04-30-03, 07:33 PM
GSL
Wiring For FLUORESCENT Tubes With Switch
NEED TO KNOW HOW TO WIRE (FLUORESCENT) TUBES AND A LIGHT TO SWITCHES FROM CONSUMER UNIT ( MAINS)
? IS CAN I RUN FROM CONSUMER BOX THE LIVE,NEUTRAL, AND EARTH DIRECTLY TO SWITCH AND THEN STRAIGHT TO THE FITTINGS. ( THE POWER FROM CONSUMER UNIT TO THE SWITCH AND FROM THE SWITCH TO THE FITTING)
Old 04-30-03, 08:11 PM
Received 1 Upvote on 1 Post
On your side of the pond, the terminology is considerably different than on our side. I can translate most of what you say, but I am having trouble with the word "tube". All of the following terms are strange here:
Tubes
Mains
Ceiling Rose
SL
Loop
The two terms I've got nailed are:
Live = hot
Earth = ground
Can you (or someone else) help with the translation?
Old 05-01-03, 07:12 PM
Gary Tait
Tubes
Flourescent tubes, perhaps the whole fixture assembly.
Mains
Electric power from the utility grid.
Ceiling Rose
Junction box specifically for lighting fixtures.
SL
Loop
Switch loop.
Ordinarily, in the UK, I'd think you'd run mains to fixture, switch loop to switch.
Old 05-01-03, 07:26 PM
CAN I RUN FROM CONSUMER BOX THE LIVE, NEUTRAL, AND EARTH DIRECTLY TO SWITCH AND THEN STRAIGHT TO THE FITTINGS. ( THE POWER FROM CONSUMER UNIT TO THE SWITCH AND FROM THE SWITCH TO THE FITTING)
Yes.
And thanks to you both for the translations.
