What exactly is a backstab connection
you strip the wires and just insert them into the back of the outlet,switch,etc.
I MIGHT BE WRONG
I MIGHT BE WRONG
A backstab connection is simply a hole in the back of wiring devices, into which a wire is inserted and held in place by a spring-type clamping mechanism. Backstabs are not to be confused with backwired, which is found on most GFCIs and higher quality devices. With back-wired terminals, you insert the wire into a hole on the back and tighten down the screw on the side. This provides a tight connection far superior to any backstab.
In any case, backstabs should not be used. They will work okay for a while, but may very well be the source of unecessary trouble down the road.
