Outlet Problem
Old 05-13-03, 12:53 PM
viclavaly
Outlet Problem
one of my outlet has no power when I connect the Electric mower to it, I did open it and when I test both the black and white wires I got around 10 or 15 volts, but when I test both the black and the grund I can get 110 volts..this outlet is the last outlet. any suggestion what should be done to solve .. Thanks in advance.
Old 05-13-03, 01:00 PM
T
You probably have an open neutral, open the last working outlet in this circuit and check the connections.
