Attic fan thermostat - kaput...
Old 05-15-03, 03:43 PM
JimmyD
Hi,
I just found this site while surfing around for a replacement thermostat for an attic fan. I would appreciate any help anyone could lend!
The fan is roof-mounted, and was installed about 6 years ago (I'm guessing) - but never hooked up/wired. The motor works checking with a hot wire, but evidently the thermostat is not operational.
I'm looking at the metal cover plate I removed, and it says "Pace Setter Professional Standard Model PT6 By Leslie-Locke" - but when I do a search on Leslie-Locke Fans, 'Pace Setter' brand, etc. I get nowhere...
I imagine I'm not the only guy who has this problem.. ... But the local Home Depot (which is probably where the thing came from) and my local ACE has nothing for what I need.
If anyone could direct me to a supplier on-line, or provide a 'lead' that might point me in the right direction, it would be great!
Kind regards,
Jim
Old 05-15-03, 07:18 PM
Andrew's Avatar
Received 14 Votes on 10 Posts
I believe Leslie-Locke was bought out by Certainteed (sp?) a few years ago. You might want to check with them.
Old 05-15-03, 07:48 PM
JimmyD
Attic Fan Therm..
Thanks, Andrew!
I'll check them out..
Kind regards,
Jim
Old 07-18-13, 05:39 AM
Y
Try MasterFlow. It appears they may be the new company name.
Old 07-18-13, 06:35 AM
CasualJoe's Avatar
Received 152 Votes on 135 Posts
I don't suppose you noticed this thread is over 10 years old.
