Short?
The GFCI that protects outside lights continually trips off. There are three lights plus receptacle. Basically the wiring is- Fuse box to Torx timer to GFCI to outside lights. How do I begin to diagnose where the problem lies. I replaced the GFCI but it still trips. Any ideas?
Some background would help. When you say "continually," do you mean within a half-second of resetting it, or do you mean overnight, or do you mean once in a while? If anything except the first answer, is there a pattern -- such as it trips in humid or rainy weather? When did this start happening, and did anything change around that time?
You have ground fault. The GFCI is doing its job.
Disconnect the wires from the load side of the GFCI. Does it reset now? If it does, reconnect them and go to the next box and disconnect the wires there. Does the GFCI reset now? If it does, ...
You can either work from the GFCI downstream, or from the last outlet upstream, or from the middle (binary search). In any event, this diagnostic procedure will tell you what box the ground fault is in. Then post back and tell us.
You may have moisture in one of the outside boxes. If that is the case, then try to seal it up better.
