baseboard heater + outlet
I'm installing a 2000 watt baseboard heater on a 240v, 20A circuit. Since I can't install receptacles above the heater, I'd like to use the optional add-on receptacle that goes on the end of the heater. Will this receptacle be wired into the same circuit as the heater itself? Or do I need to connect it to the room's general 120v, 20A circuit?
Thanks for any advice.
