current sensing switch - One more question
OK, I'm almost there. I found a current sensing relay that will close a 120 V circuit when current is sensed in another wire and I found a time delay shut-off relay that will provide AC to the fans for my projector for several minutes after the projector has shut down. All I need is a low voltage switch that will close when power is applied and will open when power is removed (like a solenoid).
Any suggestions?
Traveler
Any suggestions?
Traveler
