Lamp rewiring
I have a table lamp w/3 sockets & 1 switch w/3 positions, each position turns on 1 bulb, then 2 bulbs, then all 3 bulbs. How do I rewire this? A picture would be great? Thanks for a reply!
Make your own diagram when you pull the old wires out. The switch wil have 4 connections. One will go the hot wire from the plug and one to each lamp center contact. The neutral wire will go to each lamp outer shell directly.
