Conduit Requirement
Old 05-27-03, 05:37 AM
bfpierce
Conduit Requirement
I'm running some new 12/2 from entrance, thru attached garage, then up into bedrooms. Garage walls are fiinished with plywood. Can the 12/2 be tacked to the plywood for its run along the garage wall, or is conduit necessary here?
Old 05-27-03, 06:07 AM
texsparky
If the wire is subject to damage, you are required to protect it. We cant see where you are running it.You will have to make that call. Personally, I hate exposed wiring of any type and would either run pipe or remove the plywood and run it in the walls.
Old 05-27-03, 11:51 AM
bfpierce
Thanks for the reply. It would be running in the top corner, so I don't know how any damage could occur, but I'll go ahead and put it in conduit. Should I use pvc or metal?
Old 05-27-03, 01:32 PM
texsparky
Post
Use PVC. There is no chance of it becoming energized by a knicked or damaged wire.
