Where to tap in?
Old 06-01-03, 06:43 PM
mgn
Question Where to tap in?
Howdy,
I'm trying to complete a partially finished basement. There's already six 15amp circuits is use and I need to add more outlets and lighting. My question is does it matter where in the existing run you tap into, (start, middle or end).
thanks...
Old 06-01-03, 07:55 PM
texsparky
Post
No.
Old 06-01-03, 08:00 PM
No it does not matter where you tap into the run However make sure you know what you are tapping into. Also figure out what exactly is on the exsisting run and the loads they draw. Some times it is just easier to run new from the panel if it is accessable.
Good luck hope this helps
