Anyone know where to find a 1/8-28 NPT tap?
Old 06-02-03, 08:14 PM
MikeVB
I have a compressor with a 1/8-28 NPT fitting and I need to find a way to convert it to fit into a standard fitting such as a 1/8-27 NPT or a 1/4" NPT. Any idea who sells one of these?
Thanks
Mike
Old 06-03-03, 04:13 AM
mattison's Avatar
Have you tried www.grainger.com ?
Old 06-03-03, 05:13 AM
MikeVB
Yes I have and they don't have one.
Mike
Old 06-03-03, 09:48 AM
mattison's Avatar
You may want to post this in the tool section. Those guys can find anything I'll bet.
Old 06-03-03, 12:24 PM
T
1/8-28??? How did you determine that it was that particular thread size? I have never heard of it myself. I would think that 1/8-27 would engage o.k. anyway because you wouldn't normally have a full inch of engagement. Over an inch your only talking about an extra thread.
If it is an issue, pickup a 1/8-27 tap and chase the thread, just to be sure and add a little teflon paste to the tape.
Old 06-03-03, 01:15 PM
Received 500 Upvotes on 410 Posts
Where was the compressor made. Could it be metric. There is such a thing as 1/8 - 28. It is listed on my chart under the British & ISO pipe sizes.
Old 06-03-03, 02:37 PM
Walk right into a major auto parts store such as a NAPA. They carry almost all available taps.
Old 06-03-03, 05:01 PM
MikeVB
I determined it was 1/8-28 NPT because it is the same diameter roughly as a 1/8-27 NPT fitting but a thread pitch gauge shows it as 28 TPI perfectly. A 1/8-27 fitting engages the fitting but only for about a half turn or so.
Mike
Old 06-03-03, 05:05 PM
MikeVB
Joed,
This compressor was made in Denmark and according to their web site the hose coming out of the compressor that I am talking about is 1/8 and not metric. Their web site does not say the thread pitch though.
I thought it might be a 1/8-28 BSP as you stated, but the British 1/8-28 has a 55 degree thread pitch instead of the 60 degree we use. If it was 55 degrees it would look funny with a 60 degree thread pitch gauge on the threads. The 28 TPI gauge fits on it perfectly and the angle of the threads and the gauge look like a match which would make it 60 degrees. I am taking a fitting to work tomorrow to have the machinist look at it.
Mike
Old 06-03-03, 05:16 PM
MikeVB
Thanks Mattison.
I forgot this was the electrical forum. lol
I saved it in my bookmarks but failed to go to the starting page URL to save it.
Thanks again
Mike
Old 06-03-03, 05:25 PM
Are you sure it is not metric. My thread guages 0.9mm matches 28tpi.
Old 06-03-03, 05:36 PM
MikeVB
Joed,
I noticed that last night myself. I am not positive that it is a SAE size and not metric. I am going to call the manufacturer tomorrow and see if I can find out.
Thanks
Mike
Old 06-03-03, 05:59 PM
T
Yes, there is a 1/8-28 thread. I had to look it up for myself. It is a B.S.P. thread. I had never ran across it in my years of dealing with the threading industry. I guess you can learn something everyday.
But, in reality, I feel that in this case you could chase out this thread with a 1/8-27 tap and would not have a problem. Especially where you are only talking about a pitch difference of .0013".
You may be able to get a machine shop to turn you one out for a small fee, if they have the die available. I am a little surprised that the vendor don't have an adapter available to convert the thread to N.P.T. anyway....... Good for business and all!!
Old 06-03-03, 07:25 PM
MGJ
thread question
I work with both NPT and BSP standards daily(machinist).If I were you I'd run a 1/4-27 tap into hole then teflon tape(two wraps) fitting.Put grease on tap to catch metal chips.
Old 06-03-03, 09:03 PM
MikeVB
Re: thread question
1/4-27? 1/4 NPT threads are 18 TPI last time I looked. I thought you were a machinist? Just kidding with you MGJ. I know you meant to say 1/8-27 my friend.
Thanks for the tips. I have a fitting here that I believe is stainless and it has a male fitting and two female threaded openings on it. I think I will put one female fitting on the compressor, tap the other female fitting to 1/8-27 NPT and plug it and use a die on the male end to make it 1/8-27 also to fit whatever fitting I need to convert it from a 1/8 to the size of the braided hose I buy.
Do you see any problems with tapping stainless over brass? Will it still work alright going over the existing threads?
Thanks
Mike
Old 06-03-03, 10:36 PM
if you never care about getting it apart again locktite works great for mismatched stuff.
Old 06-04-03, 05:11 PM
MikeVB
Re: thread question
MGJ,
I took the fitting to work today and had our machinist look at it.
He said it is metric and is not pipe threads. He said it is a 9.5 x .9 M according to the measurements.
Mike
