Pool filter
Pool filter
Hello.
I'm building a deck around my pool, which will be over the filter. I need to switch the filter off to operate the valve, which I've done by unplugging the filter, which is at ground level. I'd like to place a switch at deck level. Are there waterproof switches for this? The circuit already has a GFCI outlet in it. Can I put a second one in line near the pump, and just trip and then reset the GFCI, using it as a switch?
Thanks for your help
David
David
Yes, there are waterproof switches. Ask for them at any home improvement center. Don't use a GFCI receptacle as a switch. It isn't designed for that, and it probably wouldn't last long if used for that purpose.
