Electric Heat???
Old 06-19-03, 10:26 AM
jcpike
Electric Heat???
I am having my electrical upgraded from 60 amps to 200 amps.
I currently have hot air oil fired furnace, but have been thinking about replacing with electric heat when it's time to replace the furnace, maybe 5 years.
The house is a one story, the basement is not yet finished (drywall etc...)
I would like to have wires at least in place if and when I decide to install electric heat.
Could I run wires up to my attic from the panel (not hookup of course) and later hookup heaters and thermostats?
If so how many wires etc....?
Any suggestions appreciated
Cheers
JP
Old 06-19-03, 11:35 AM
Yes, Just make sure that the wires terminate in a junction box and each conductor is capped with a wire nut. This way there is little chance for an accident.
Old 06-19-03, 05:42 PM
Received 491 Upvotes on 403 Posts
Or you could run conduits from the attic to beside the panel and install wires later.
