two outlets do not work and the wiring
Old 06-19-03, 04:37 PM
jaylittle
Angry two outlets do not work and the wiring
i have two outlets that do not work and the wiring to them are dead i have a Circuit-breaker box and none of them are tripped
what should i do help !
Old 06-19-03, 05:36 PM
Received 491 Upvotes on 403 Posts
Where are the receptacles? If they are in a garage, bathroom, basement, outside, or near a sink they could be protected by a gfci.
Old 06-20-03, 06:48 AM
jaylittle
they are outside
if they are there is no button to turn them back on and they are outside i do not see a gfci outlet on them
Old 06-20-03, 08:50 AM
P
If these are exterior receptacle outlets they could be on the "Load" side of a GFI receptacle in another location, such as a bathroom.You must check all GFI receptacles for a "Tripped" condition.----Good Luck!!
Old 06-20-03, 04:32 PM
Received 1 Upvote on 1 Post
Tell us what year the house was built and we might be able to give you a better guess as to where to find the GFCI.
Old 06-21-03, 07:03 AM
jaylittle
thank you it was on the load side of the only gfci outlet in the house and it was at the other end of the house i did not even think of looking there thanks guys you are great
