Electrical component located in wall unit bed
Old 06-27-03, 12:54 PM
PKOEPKE
I have a wall unit bed with overhead lights. There is a module that has two receptacles, phone jack and dimmer switch for the lights overhead. The dimmer switch stopped working, but everything else is fine. How do I fix this and, if necessary, where do I find a replacement for the entire module?
Old 06-27-03, 01:36 PM
Received 1 Upvote on 1 Post
Do you mean that the dimmer no longer turns the lights on, or that it still does turn the lights on but no longer dims them?
You might shut off the breaker, and pull the module out of the wall (carefully recording how all the connections are made), and then disconnect it. If it looks like a specialty item, take it to a store that sells this type of bed. Or get a manufacturer name off the unit and call them and/or visit their web site.
Old 06-27-03, 02:32 PM
PKOEPKE
Electrical Component in Wall Unit Bed
Thanks for the quick reply. To clarify, the dimmer switch doesn't work at all; not for turning on the lights.
