I need to cut off power.
Due to a kitchen remodel, I need to temporarily cut off the power to a few outlets. I can't turn off the breaker during the whole remodel period because other outlets and lights on the same circuit need to remain functional. Fortunately (I think) , the ones I need to cut off are at the end of the line.
To illustrate, power runs to outlet A, and from there to outlet B, and then to outlet C. Assume I want to keep outlet A functional, and want to kill off B and C. What I was thinking was that I would remove outlet B and do my thing with the incoming wire at that location. Question is, do I wire-nut and tape securely the black wire by itself, and do the same with the white wire and tuck them away safely out of the way...or do I just wire-nut the black and white together with a single wire-nut?
Thanks.
Thanks.
