Running Conduit through stucco
I'm not sure if this is the right place to ask.
We're trying to run 3/4" conduit through wood and stucco to our main panel outside. We have a 3/8" shank drill and a 3/4" mortar bit. Since the 3/4" is the inside diameter of the conduit, that's not big enough (not to mention the bit is very long and looks like it would be scary to wield). I have found a 1-1/4" hole saw with a carbide tip that will fit our drill, but I think the outside diameter of the conduit is only 1". I'd like to be able to get this work done soon and without having to buy a whole new drill. Is that possible? Is there another way to get this done?
Any help would be appreciated!
running conduit thru stucco
I've just been thru this. Go ahead and use your 3/4" bit. Wobble it in the hole to open up the stucco a bit. Then use a tiger saw with a blade called "the axe" to open up the wood beyond. Takes just a few minutes, and is a great excuse to buy a new tiger saw!!!!
