stripping 6 ga wire
stripping 6 ga wire
What's the best way to do this without nicking the wire. None of the wire strippers I've seen locally can do this.
stripping AWG 6
mskreis,
No. 6 wire is sort of in-between. I know of only one pliers-type stripper that'll handle wire that big, and they're made by Ideal. And they only go up to #6 solid.
Usually the bigger stranded conductors don't strip well with pliers-type tools, because the insulation fills the space between the outer individual strands of the wire (which are each about equal to #18).
And there are strippers with swivel blades for real big stuff (#2 and up). They allow yo uto make a ring cut and then a lengthwise cut (actually two or three longitudinal works better). Then you peel the segment of insulation off. Very neat.
The best way to strip #6 is to use a very sharp knife. Skin the insulation off the same way you'd sharpen a pencil--shave the insulation off, cutting at a shallow angle, so as to not nick the copper. Whittle around the wire. The shoulder will look kind of funky, but do not make a ring cut to neaten it up--more than likely, you'll nick the conductor, and that is very bad. Very, very bad--from both an electrical and a mechanical perspective.
And bungalow jeff, you have it backwards. #6 is not narrow gage. Not by a long shot.
Cliff
Cliff
