changing light switches
i have a hallway with 3 switches that control one light. i am planning on updating the switches to a teeter-totter type. my question is what kind of switches do i need to buy? do i need three 4-way switches or one 4-way and two 3-way. any help would be greatly appreciated. thanks!
You need one 4-way and two 3-way. You must replace the existing 4-way with a 4-way, and the existing 3-ways with 3-ways. When replacing the switches, be aware that screw position and wire color mean nothing. You must examine the markings on the old and new switches and match equivalent functionality. On a 3-way, one of the screws is black and/or is marked "common" or "com". The same wire must be on this screw on both the old and new switches. On a 4-way, two of the screws are marked "input" and two "output". Connect each wire to the screw with the same marking on the new switch.
Replace the switches one at at ime and test after each switch. That way if you get a switch wired wrong you will know which one is wrong before you procede on the next one. If you 2 of them wrong at the same time it can be very difficult to straighten it out.
