Wierd electrical problem
Old 07-01-03, 12:06 PM
yoturaja
Hello,
A month ago I installed a ceiling fan which has two internal switches; one that controls the light and the other to control the speed of the fan. The power for the fan is controlled by a wall switch, so when i wanted to turn on only the fan I would flip the wall switch to on and turn off the light switch on the unit. Everything was cool up to yesterday. Now the fan works partially when I turn off the lights, it makes a buzzing sound and barely moves, but when i turn the lights on it works fine. Seems like the power to the fan is weak and it gets stronger just when I turn the lights swith on. Any help would be greatly appreciated.
Thanks in advance.
Old 07-01-03, 01:01 PM
fatkid66's Avatar
when you say turn on the lights are you referring to the wall switch or the internal switch?
Old 07-01-03, 01:16 PM
yoturaja
Thanks fatkid for your reply
I am referring to the internal switch.
Old 07-01-03, 01:24 PM
fatkid66's Avatar
sounds to me like an internal problem w/ the fan. Too late to remove and return?? if so contact the manufacturer, ive had personal success in dealing w/ manu's for fans. (depending on who it is!)
Old 07-01-03, 01:30 PM
yoturaja
I thought so. Yep, i think is kind of late to return it. I would try to contact the manufacturer. Thanks a lot for your time.
Old 07-01-03, 01:35 PM
fatkid66's Avatar
you are sure the fan is wired correctly right?. hot to hot, neut to neut?
Old 07-01-03, 01:37 PM
Received 1 Upvote on 1 Post
The wall switch is not a dimmer switch, is it?
Old 07-01-03, 01:46 PM
fatkid66's Avatar
John, sorry i didn't think to ask that one!!
Old 07-01-03, 01:54 PM
yoturaja
John, FatKid:
Yes as the matter of fact it is. It is one of those that deems just by touching it. Hmmm, so when I turn the switch on it is probably dimmed down so not enough juice to move the fan?
Old 07-01-03, 03:02 PM
Actually, I was thinking you may have permanently damaged the fan motor by using a dimmer switch it was not designed for.
Old 07-01-03, 03:12 PM
yoturaja
The motor works when the lights are on at the same time. This makes me believe that something else broke beside the motor. What do you think?
Old 07-01-03, 03:29 PM
fatkid66's Avatar
i would swap out the dimmer for a single pole switch, and hope for the best.
Old 07-01-03, 03:39 PM
yoturaja
Will do. Thanks FatKidd and John for your time.
