electricity
Old 07-06-03, 05:10 AM
ingalvestontx
electricity
Hi...I have a question for ya.....Do 2 110 air conditioning units equal 1 220 unit?
Old 07-06-03, 05:33 AM
HandyRon's Avatar
Do you mean for cooling capacity? Two 9,000BTU, 120V units will cool the same as one 18,000BTU, 240V unit. You might even get more cooling efficiency and temperature control for a larger space since they will cycle on-off as needed for their particular areas.
Electrical efficiency is probably similar, although the larger unit might require a bit more current to overcome the larger compressor HP.
