Run on timer for ventilation fan
Old 07-11-03, 10:47 AM
P
I was wondering if these exisited for use here in NA.
In Australia and NZ they are recommended to be used with the fan switch in bathrooms. Basically they provide power to the fan for about 10 minutes after the switch is turned off, so when you leave the room and turn off the fan it continues to run and completely exhaust the moist air.
Haven't seen any, but haven't undertaken an exhaustive search yet.
Old 07-11-03, 11:49 AM
C
Here is one example:
http://www.rewci.com/fandetisw.html
Hope this helps.
Old 07-11-03, 12:54 PM
P
Indeed it does. Thank you very much.
