red outlet
Old 07-16-03, 11:06 PM
Jason T
red outlet
I have one outlet in the house I just bought that is red. Does this mean anything specific or is it just the color of the outlet. The outlet itself is red not the plate.
Jason.
Old 07-17-03, 05:59 AM
texsparky
It is most likely a hospital grade, isolated equipment ground receptacle. Someone most likely installed for electronic equipment if the house is wired with metal conduit and metal boxes. However,if the house is wired with type NM ( romex ) and plastic boxes, the ground is already isolated. Then the receptacle would serve no purpose as far as isolating the equipment ground
Old 07-17-03, 06:37 AM
Make sure it is grounded and someone didnt think it was going to ground thru the yoke to the box.
Old 07-17-03, 09:06 AM
Received 2 Upvotes on 2 Posts
...or, I've seen some people install colored receptacles for aesthetic reasons (decorating). Mostly back in the '60s though...
Juice
