Insulation - clearance to electrical box/lighting cans
Hi,
putting R13 insulation in the walls and ceiling. Walls and ceiling is exposed.
Q1) Do i need any clearance from the insulation to the electrical box ?
Q2) Do i need any clearance from the insulation to the lighting can? (recessed lighting to be installed)
thanks
thanks
Q1 no the insulation can be on or touching an electrical box
Q2 Maybe what type of can is it? If it is reted for insulation contact I/C then yes but if it says NON-I/C then the answer is no
