changing a switch to an outlet.
Old 07-24-03, 09:54 AM
Jadian10
Smile changing a switch to an outlet.
I removed the garbage disposal from my kitchen sink and would like to change the switch that operated it into an outlet. In examing the wiring, I see two white wires connected with a cap, and the two black wires connected to the switch. I am sure that in order for this to be an outlet, one of the white wires and black must be joined with a cap and one black and one white must be connected to the outlet. But I am not sure which ones to connect together?? Any help or advice appreciated.
Jadian10
Old 07-24-03, 11:49 AM
P
Dis-connect the switch and seperate the 2-White wires-best done with the power Off at the circuit-breaker. You now have 2 Black wires and 2 White wires which are the ends of 2 cable-pairs, each cable-pair having a Black wire and White wire. One of the cable-pairs is the 120 volt "feed" which will connect to the receptacle. Locate the "feed" cable pair by testing for voltage Black-to-White.
If this will be a counter-top receptacle-outet, use a GFI receptacle. Insulate the ends of the wires of the "dead" pair, being careful to keep the ends seperated.-----Good LucK!!!!!
Old 07-24-03, 08:23 PM
Received 1 Upvote on 1 Post
There's a really good chance that making this modification will create a code violation. Perhaps not the most serious violation in the world, but a code violation nevertheless.
Old 07-25-03, 07:57 AM
Jadian10
John I am not sure how this would violate code. The garbage disposal was on a separate circuit all by itself. In changing the switch to an outlet, the outlet below the sink will be dead. But I will check it out. Thanks for the advice.
Old 07-25-03, 08:16 AM
Many garbage disposal circuits are 15-amp circuits. Receptacles serving kitchen counter surfaces are required to be 20-amp circuits, with a few exceptions. I would need to know more about your project and the purpose of this new receptacle. Another possible issue is what, if anything, was on this circuit other than the garbage disposal. That's why I only indicated that there is a "chance" of a violation.
Old 07-25-03, 09:01 AM
Jadian10
John, There was nothing else on this circuit other than the garbage disposal. The only need for the outlet is to plug a toaster or can opener into. And then it would only be occasionally. I just thought an outlet would be more useful than a switch to something that no longer exists. If it is truly an unwise thing to do then I won't do it. I have one other outlet on the same wall (different circuit) and an outlet on an adjoining wall (different circuit) It's not that I really NEED the outlet, just thought it would be handy. Thanks
